Re: Mercruiser 305/5L V8 MCM228 engine block
I agree. Put a 350 back in your boat. You need a 1980 to 1985 vintage which will have the two piece rear seal and will work with your flywheel and starter, and bolt right back in to your transom plate and motor mounts. All the peripherals fit also. I would not buy a junk yard block. Too many unknowns for me. Too much work to put it all together and find out it has a problem, or is worn out etc. Also, you need a truck engine anyway, because the cams are closer to what a boat uses do to torque requirements. You can get a rebuilt marine 350 engine without valve covers, oil pan and timing cover (the "tin") for around $1500.
