Hi, my 2004 280 sundancer engine (starboard) will not start unless I engage "emergency start". Seems as though there is no battery power. The windless will not work either. Could hear it engaging but will not turn. The Port engine starts normally.
Removed the batteries last winter and stored them inside. This problem occurred when I first tried to start the motors this spring....just thought it was low batteries.
Installed two new batteries today...same problem...starboard engine cranks a little then clicking. Engage emergency start, she starts right up. Port engine starts no problem.
All batteries (new and old) are reading 13+ volts...both separately and when installed on the boat.
What do you think, did I install the batteries wrong, are the batteries bad, or is there something else going on.
Thanks
Fred
Thanks
Fred
