Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
3. Do not take over someone else’s topic (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new topic of your own.
5. By starting your own topic, you will receive the maximum number of views by forum helpers that may not even notice your question when it’s posted at the end of someone else’s topic. And those answers will be specific to your particular issue.
See more
See less
Electronic ignition conversion
  • Electronic ignition conversion
    Hi guys,
    I have a 1982 boat powered by a Mercruiser 120 GM 2.5L engine. I've had some grief in the past with the points and I want to convert it to an electronic ignition.
    I found the following link but I don't feel 100% confident that this is the correct part for my motor.
    Pertronix Ignitor Ignition Coil Wires Mercruiser 120
    Would someone be able to help me confirm?
    Thanks!
    Rob
    Re: Electronic ignition conversion
    Ayuh,.... If yer serial numbers fall within the ranges, Ya, it oughta work,...
    gnitor system and flamethrower coil 12V Negative Ground for
    110 from serial 1537370 to 2044033
    120 from serial 1666601
    140 from serial 2508261
    165,170,180,190 from serial 6916779
    470 from serial 4208730
    470R from serial 6218037
    485 from serial 5685394
    488R from serial 617029
    • #3
      Thanks Bond-o!
      Originally posted by From Mercury site
      You can locate the MerCruiser serial number label on either the the side of the engine or on top of the flame arrester cover.
      Is this serial number on an identification plate or stamped into the block casting?
      I don't have my boat nearby. I could call to get the number read back to me but it would help if I can let them know where to look.
      • #4
        I would not go with the Ignitor, I would advise going with the Ignitor II (91146A) paired with a Flamethrower II coil (45011, oil filled or 45111 epoxy). The Ignitor II is newer technology, with some added features, and with the Flamethrower II will give a hotter spark. A little more expensive but in the long run worth it IMHO. Here is the info on both: http://www.pertronix.com/catalogs/pd...ition_conv.pdf and the coils http://www.pertronix.com/catalogs/pd...2012_coils.pdf
        Terry
        87, 4WINNS H 190
        470/Alpha I
        • #5
          I don't think the 120 is going to see any performance increase with the Ignitor II. I understood the Ignitor II was better for custom tunes or modified engines. I plan to leave mine stock. My understanding was that the dwell was adjustable on the version 2 but looking at the material suggests that the dwell is adjusted dynamically by the controller? How does it do that?
          • #6
            As I understand it, in the past the Ignitor could be damaged by leaving the key on, don't know if that is still true. How it works? Just a guess here but it looks like there is a tachometer in the module and a linked timing circuit that increases dwell (length of time current flows through the coil, eg. points are closed in a points ignition) to maximize the spark at a given RPM. All done by a microprocessor. One thing, before you put in the electronic module put in a new set of points, and adjust the dwell. When you remove the old distributor plate seal it in a bag and keep it some place handy just in case the electronic module should fail sometime down the road. I keep mine in the glove box LOL.
            Terry
            87, 4WINNS H 190
            470/Alpha I
            • #7
              Yep, get the ignitor II along with the flamethrower II. I have that on my 120. Like stonyloam posted the ignition module will burn out if you leave the key on with the original Ignitor.
              83 Sunrunner 16.5 120 merc Alpha 1 drive SOLD 8/1/13
              1996 Crownline 202BR
              5.7l EFI 0f791070
              Bravo I drive
              GMC Yukon tow rig
              • #8
                Do you have part numbers? I'm having trouble confirming if I need Pertronix 91146A
                • #9
                  That is the one I used on my 1983 120.
                  5.7l EFI 0f791070
                  Bravo I drive
                  GMC Yukon tow rig
                  • #10
                    Thanks!
                    • #11
                      Yes, the Ignitor can be damaged if the key is left in the "on" position. The Ignitor II incorporates auto-shut off features that keep it from being damaged if the key is left "on".
                      1976 Mark Twain 200VBR w/Mercruiser 233 (Ford 351w) "Heart & Soul"
                      • #12
                        Does anyone know what the output of the standard coil is? I just replaced the coil and if I can use it, it would save me $50. Thanks.
                        • #13
                          Should be no problem, just if it is a stock coil you need to keep the purple resistance wire on the coil, and run a full 12volts to the Ignitor or (II). Best place to splice in is at the choke connector. I used solder and coated with liquid tape. Stock coil should be around 30,000 V.
                          Terry
                          87, 4WINNS H 190
                          470/Alpha I
                          • #14
                            Where would I find the choke connector?
                            • #15
                              You may not have an electric choke so you would need to find another 12v source. When I did mine I ran it along side the resistance wire to keep it clean then rewrapped the wire bundle.
                              5.7l EFI 0f791070
                              Bravo I drive
                              GMC Yukon tow rig
