Freedom9811
- Jul 22, 2013
- 4
1992 Mercruiser 454 Magnum, freshly rebuilt three summers ago with less than 20 hours.
Back firing / popping at 2000 rpm coming from left bank exhaust.
I have already replaced and checked the following this year to resolve this issue with no luck:
Compression tested all cylinders
Spark plugs
Wires
Cap
Rotor
Coil
Ignition sensor
Fuel filter
50 gallons fresh high test
Took apart carb, fully cleaned
Pulled exhaust manifold and valve cover and checked all movement of values and pushrods, all okay.
This season I haven't messed with timing, timing was fine. Could the initiation module be causing this. It's the last
thing I can think of replacing. I have read about tachometers causing problems, I do have graftion garages, which were installed at the time the motor was rebuilt three years ago.
Spark plugs
Wires
Cap
Rotor
Coil
Ignition sensor
Fuel filter
