monterey 225
- Jul 21, 2013
- 1
I have a 1994 Monterey 225 with a 5.7 mercruiser with alpha 1 outdrive. The engine runs fine at idle and revs up when not in gear but backfires through carb and barely will run when put under load. I can barely get 1800 rpm out of it. I have drained and cleaned the fuel tank, replaced fuel lines, replaced fuel pump and carburetor. Engine has new plugs, wires, coil, cap and rotor and has had a compression test and passed. Please help summer is slipping by.
