John3
- Jun 17, 2010
- 136
The Engine had been running fine. I went to start it, just to keep it lubed & running after a couple of days idle. It backfired, & ran rough as a cob. I removed the rocker arm cover. One of the # 6 Valves was stuck closed & the Rocker Arm Stud which was press fit in at the factory, had pulled out.
I tapped the end of the stuck valve with a wooden mallet, it moved slightly. But was still stuck. Sprayed with WD40, more tapping and then I gripped the valve stem with vice grips more WD40 & I rotated it. I worked the valve free. Can now move it in and out by hand.
I bought a threaded rocker arm stud. I think that may have been a mistake. Probably should have used a new press fit stud & held it in place with High Temp. Lock-Tight. Anyway I used a threaded stud. I tapped threads in the head for the stud, still had to use High Temp Lock-Tight on the threads because it unscrewed when the motor ran.
It?s now running, compression is low & leak down test on that cylinder is NG. Probably needs at least a valve job. Hope the piston & cylinder walls are ok.
Any thoughts on what I could have done to prevent this mess? The motor was completely overhauled last October. It?s still under Warranty. Guess I?ll find out how good the Jasper Warranty is.
I?ll update later.
I?ll update later.
