I have a 1985 Glastream with an Alpha 1 drive. My red 3/4" water inlet hose was kinked and was restricting water flow so . I took the gimble housing off to do a bellows repair job. My repair kit came with the same 3/4"hose that cannot be installed without it also kinking. I see some Bravo drives have a preformed hose and I would like to get a preformed hose to install on my Alpha drive. Does anyone know if a preformed hose is available for the Alpha drives? Will the Bravo hose work? If so, what is the part number? Finally, I went to the Auto Parts store and searched through their wall of preformed hoses and found a 3/4" heater hose with a 90 degree bend on one end and a suitable shape to fit. The hose is not as heavy duty as the 200psi hose in my kit. I can't see why I need 200psi for this hose and it would seem to me that having no kinks or water restriction would be more important than having such a heavy hose. Please let me know if anyone else has solved this issue. Thanks.
