I have a 1978 mercruiser 470, just went with a 1-wire alternator conversion kit.
I removed the old regulator, which was wired like this:
Boatinfo - Mercruiser Service Manual nr. 2 - 1974-1977 All Engines & Drives
I cut and taped off the two yellow wires from the stator. I removed the red jumper wire from the top right of the regulator (which went to solenoid). The other wire which was red/ white stripe was connected to the bottom right of the regulator and according to the wiring diagram goes to the ammeter. I cut and taped that off at the regulator because I read that an alternator might generate to much current and could burn up the wire and or gauge
I ran the red wire from the alternator directly to the solenoid, and the ground to a valve cover bolt. I thought I was good (although obviously the ammeter wouldn't work anymore). My plan was to replace the ammeter with a voltmeter.
Tried to fire up the boat and it won't start. Turns over, but won't start.
Do I need to have the red/white wire hooked up to something?
any other suggestions?
I told the kids I'd take them out in the boat tomorrow. Any help would be awesome. Thanks in advance.
