Mercruiser hydraulic lines
mfuller61
I need to change my hydraulic hoses from the pump to the stern drive. The gray hose rubber is rotting and exposing the white branded material. I do not have a repair manual for a 1984 mercruiser 4 cylinder inboard/outboard with mercruiser outdrive and need some advice.
Don S
Re: Mercruiser hydraulic lines
The manual is of no help in replacing the hoses, but this should help you understand how to do the job.
