mastercylinder63
- Jun 13, 2010
- 36
I took my boat out on a shakedown cruise. The Starboard engine is a 2009 4.3 carb motor. It always read a constant 40psi, but today was different. After an hour of use, the alarm went on and oil pressure dropped near zero. I shut the motor down for 15 minutes and then restarted it. I got 25psi @ 750rpm idle. When I hit 1100rpm the pressure goes back up to 40psi. I don't rev the motors more then 4500rpm. The oil is fresh 5-30w. I'm going to check it tomorrow and start the cold engine. I guess if it reads 40psi it may be the oil weight or brand, I'm not too sure. Every year I use Castrol, but this year I used Mobile, but the port engine is a solid 40psi at all rpm's. Any suggestions???
