Re: alignment of mercruiser
Need help myself with alignment: I had the bottom drive replaced and was told the motor needs alignment but still the person put the drive back after installing the lower unit,without alignning the motor. Can I do the alignment without removing the sterndrive, by going to the motor mounts ? If I remove the sterndrive and the Spline tool doesn't goes in as I've seen on the videos, do I make adjustment on the front motor mounts until I'm able to have it parallel with the insertion of the spline tool ? Why the person removed the top section of the sterndrive gets me, as to why remove that section when all I needed was the lower unit.
