Ign coils are packed with oil. If yer hearing it slosh it's probably leaked to the point of needing to be replaced. 2 basic coil types internal resister or external.
Bondo I laughed so hard i spewed beer through my nose at that one. Drew i went out and shook my brand new, in the box spare coil and it did slosh. I think its perfectly normal. Your coil is prob good as far as that goes but you need to slap a volt/ohm meter on it to check everything else.
My running motor shows 11.65-11.7 (dont know if thats what it is supposed to be but it runs)volts at the pos + side of the coil and 8.95-9.25 at the neg -. Like Bondo says if your looking for spark when was the last time the points and everything else was checked. Do you have a dwell meter? Timing light? I have a spark tester that you put your wire boot on and ground. I think you can do the same thing by pulling a plug and grounding the electrode.
I haven't got it started, i bought it used and im trying to start it before i put it into the boat. So I shot some starter fluid down the carb and jump started it and when it didn't start i went to check why and i notice the coil was really hot
