So I installed a new rebuilt carb on my 3.0l beachcraft. The boat will idle fine and run at low rpms but when I give it throttle or I am just cruising it hestitates and drops RPMs. Prior to replacing the carb it ran great other than it would never start do to a bad float. I was at lake mendo 3 weeks ago and it ran bad and then died and would not start, so I continued to try and start it. Im wondering if the plugs got so fouled from me trying to start it for a hour that its causing this problem or using 87 octane gas and letting it sit in real hot weather for 3 weeks has caused it to lose octane? my idle sits at 750 rpms and I do have a water/ fuel separator and new cap,rotor and wires. Any input would help?!
![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
