Hey all, breaking down my old mc-1 gimbals.... and let me let you it has been a nightmare so far... had to shear both of the pivot pins little nails and the lower swivel pin's cotter pin. Just if anyone is wondering yes you can shear them quite easy with heat heat and a small hammer and punch, only reason i say small hammer i was afraid of breaking the gimbal ring. so now i am to the upper pin. from what the maual say i need to remove the hex socket bolt first then pull the upper pin. so i have not been able to get the socket bolt out, so first question anyone know how far it is actualy threadedi can see theaded on one side. i have it soaking in pb blaster and i used heat heat and more heat and different bolt lossener fluids none have worked so far, Advice? As soon as i get that out anyone know what size threads are in the upper pivot i and probably going to have to chase them or step it up a size. Also what is the little screw at the very top of the houseing for?
