Re: High Oil Pressure on 4.3l Mercruiser
That seems a little high. I think you try to put a calibrated gauge on the engine and see what it really is. High oil pressure can be indicative of water in the oil as well. It won't show on the dipstick though...
Volphin....last fall I did the oil change b 4 storage. During winter months I had a catasrophy that the bilge filled up with water up to the engine and froze (long story). So beginning of season I again changed oil just to be on the safe (any water intrusion, in which I did not see any). After a few runs out this season, I discovered it was low so added oil.....Ooops, too much! So I drained some out (which indicated no water in the oil) and to bring it back to the ok zone on the stick. (I have the factory drain hose system on engine which is convenient). Now unless this drain system is not at the very bottom of the pan, there could be a bit of water below the drain system??? Which brings up another ? of how to remove that oil.
Also how would one hook up an oil pressure gauge to verify correct oil pressure?....just go off of the one on the dash? Thanks for any input!
