Re: ken
Thanks to all who replied. hit submerged log with outdrive and prop, stainless steel 4 blade, after that could only obtain just above no wake speed, any attempt to plane out caused engine to rev but no more speed, sound like vehicle with slipping clutch. engine is a 502 merccruiser (gm) 425hp, prop hub is not spun, so thats why i pulled out drive, figuring clutch would be next in line to go. It looks like new no metal shavings, chipped gears, or broken bearings that i can c from outside visual inspection. universal joints have tiny amount of play so not the problem. Could there be a problem i will find if i dismantel ? if not i guess only thing left would be to pull motor:grumpy: to c if power transfer plate has gone bad. i did not smell burning rubber but my engine compartment is well sealed and i did not open it at time. engine is 2005, outdrive is 1995 vintage, bravo 1, 7.4 L, prior engine was a 454. thats all i can think of as far as info goes. appreciate ur feedback and thanks again. Ken
