Re: til trim meter
Merged your two threads together since they ask the same thing.
Might want to post your fuel gauge problem over in the electrical forum, and look at the stickies there. All kinds of info on the fuel gauge there.
Your trim gauge and sender however is part of the engine system. Check the trim sender with an ohm meter and see if it works smoothly through it's range. Usually the wires fall off of them before anything else goes wrong.
