RCAnderson
- Oct 5, 2011
- 68
Re: Mercruiser 4.3 overheats at idle only
Not doubting you, but how would a cracked head result in no cooling at idle, but only when in the water ?
What type of coolant is this system using? You need 50/50 Ethylene Glycol... the green coolant. Dex-cool has been known to cause issues. Has the circulation pump been changed? If so, make sure it is the correct rotation. Consider a higher flow circ. pump... Worst case scenario is a cracked head.
