trendsetter240
- Jun 22, 2009
- 1,458
Mercruiser 4.3 carb, alpha one gen 2 (1995 model year I believe). Engine was originally raw water cooled but has an aftermarket fresh water cooling system in place.
Hi guys, I'm helping out a neighbor with an overheat issue on his mercruiser. The symptoms are that the engine will run at a normal temp when cruising, pulling tubes, full throttle etc. It will overheat when brought back to idle. This doesn't happen on water muffs only when the boat is in the water.
I have pulled the lower unit and inspected the impeller which appears to be fine. I will replace it regardless. I've also pulled the thermostat housing and it appears normal (no rust or blockages). The thermostat was replaced last year and did not correct the issue. This is not one of the thermostat housings that have the check balls.
Any ideas on what else I should check while I have the boat? I'm kind of at a loss and if no suggestions plan to replace the impeller and take the boat for a water test to see if I can reproduce the issue.
Cheers
Cheers
