mercruiser 165 hp inline 6 lower unit / shift linkage problem
driv3nx
I recently dropped my lower unit and greased and inspected it everything seemed fine so I put back on exactly howit cameoff now it is stuck in reverse I believe . shifter in forward is neutral and neutral is almost engaged likeI hear clicking sounds and then reverse is forward I believe. isthere something I'm missing here I'm completely stuck tried everythingIcouldthink of please help
alldodge
Re: mercruiser 165 hp inline 6 lower unit / shift linkage problem
Is the shift arm lined up with the shoe? You can see it between the two halves.
