Mercruiser 4.3
orange wire on alternator on start up goes to 14. +or- volts.
After a min or 2 as engine temp inreases (which don't know if it has anything to do with anything) the voltage drops down to 12 volts and stays there. This is being determined by volt meter.
I found a previous thread on how to test all wiring and components that don s. Had posted. I checked everything and it was fine.
Assuming it's the alternator but i had it bench tested at marine supply store and was charging 14.8 volts.
