sptjet90Reflexx
- May 28, 2011
- 383
4.3L v6 Merc 1989.
Was having a no spark issue originally. Turned out to be a bad ground, so I left the main engine ground on the motor but moved the ground for the ignition system directly to the battery. Motor starts every time.
Recently replaced the sea pump, shift cable, bellows, steering system and coil on the boat. Today was the first time I had this boat in the water since I bought it a few months ago. Started up in the water with no issues, and pulled out of the no-wake zone and proceeded to WOT. She got up and got on a plane, I left the trim all the way down for now didn't want to fiddle with it on the test drive. after about 4 minutes she just DIED straight dead. Attempting to start her back up it was almost like battery was dead, so I fiddled with the battery cables and she started back up again. after that though it was weird, I couldnt run her at WOT without her tryin to die out, but backing off throttle she would kick back to life.. very strange. sometimes it would be fine other times it would bog out..
Im going to replace the whole ground with a new cable entirely as well as the + cable. Anyone else have suggestions?
