Everything I read says the rotors turn clockwise... both of mine turn counter clockwise. Since my rotor turns
Yes, they always turn clockwise. Even on counter rotating engines. You say BOTH of yours turn CCW. Assuming that means you have twins, did you by some chance switch starters?
block mounted or aft entry starters. If aft entry just swap the starters
Yes I have twins. Starboard engine flywheel is clockwise, port is counter clockwise. The rotors both turn counter clockwise. I did have the starters out...didn't think it was possible to mix up which when to each engine.
The engines turn opposite directions, which means the starters have to be different. The rotors ALWAYS turn clockwise. Doesn't matter if they are block or aft mounted.
you do realize the firing order is different even though the rotors turn in the same direction.
