Re: Pics of pressure/vacuum gauge in use
You need to make an adapter hose for testing.
Then remove the steel line and replace it with your test setup.
You need two fitting adapters that go from the fuel pump and carb connections to a hose long enough to go between both.
Then put a tee in the hose at a convenient place, and hook your gauge to the tee.
