Jacalore
- Jun 3, 2013
- 457
Problem: 1985 MerCruiser 3.0L 140 No Acceleration - dies above 1500 rpm
Background: Bought boat with "carb" problem, prev owner said he rebuilt carb but didn't replace float, resulting in no acceleration. I attempted to rebuild carb, but threads on carb at fuel inlet stripped, so I replaced with a carb from a 1986 engine with identical part numbers. On muffs, ran smooth, idled ok.
Today: On the water for first trial run - no acceleration above 1500 rpm. Runs all day below that in forward/reverse. Easing the throttle up, or not, stalls above 1500 rpm.
I assume this is the original problem, and not the carb. Where do I look for likely problem?
Thanks
Thanks
