Hello All,
here is the issue I am having:
-out drive would not stay up when trimmed, the hydraulics wouldnt hold it up
-replaced the trim pump, that helped some. it still leaks down, but very slow, it will drop about 3 inches at first, with in a couple minutes, then leak the the rest of the way down over a couple weeks
-I have bled the system, (ran tilt up and down several times
-there appears to be a very lite amount of fluid on the ram it self, nothing leaking out that I can see
-is it possible just a rebuild kit will take care of the bleed down?
-also, should the up and down speed be the same?
-it trims up really fast, but trimming down will take 4 times longer
-not sure if that is normal or if something is connected wrong.
any help is much appreciated
-it is the pre alph drive that I am working with.
