Hey Y'all got a strange one.
I have a '79 120 lower unit w/ a rebuilt 3.0 motor, long block, which I installed a few weeks ago.
Test ran with the muffs. Ran fine, shifted fine. The drive has never given any probs before. When we put her in the water it didn't want to start. When i got it to start, by throttling up a bit, the prop was engaged and I could not get it to go into neutral.
Pulled her out, took it home, checked the cables and linkage could not see a problem. Hooked up the muffs, started up fine. Ran through the gears/ neutral worked fine. Soooo put it back in the lake..same thing!
I noticed when I turn the prop backwards now when its in gear I can hear the clutch dog clicking. I'm not sure but I don't think it did that before.
Any Ideas? Bend shift arm?
Scott
Scott
