Since I'm fixing all my other recent problems with my boat I might as well fix one I've had for years.
93 Bayliner, 3.0L, Alpha 1 Gen 2.
Ever since I've owned the boat, about 6 years now, it has always hesitated when accelerating. I've never been able to go from a crawl to wot. So if I'm going at 1/4 throttle and hit the gas it will start to stall and I have to bring the throttle back and kind of pump it and then go wide open. It idles fine and goes wide open fine, it's just when accelerating.
From my research I've seen some similar problems and the solution is accelerator pump and I should rebuild my carb, sound like a good place to start?
Thanks!
Thanks!
