21seapro
- Dec 18, 2010
- 16
I have a 2000 254 Larson cabrio with a 5.7L mercruiser with a 2 barrel carb. The problem I'm having is ill be on the boat cruising at 3500rpm and all of a sudden the engine will fall flat on its face and I would have to cruise the rest of the way home in idle. (1500rpm). I found out if I remove a fuel/water sep and reinstall it the boat will run great again for only about 1-3 min if that. I repeat the process again it goes again for another 1-3min. HElP please.
before the boat went into the water I replaced fuel pump, fuel/water separator, water pump, rebuilt carburetor, drained 5 gallons of fuel from the bottom of the tank, plugs, wires, cap, rottor; and Bravo 3 outdrive.
when I had the problem for the first time I replaced fuel water separator, drained more fuel from tank, and fuel hose. And i still have the problem. When the boat sits overnight I could run the boat at idle for hours when its running at 3500 rpm it will run great for about 20 minutes and that's when the problem starts.
