Bridgerecording
- Jun 17, 2013
- 2
Hi all, here's hoping someone out there can shed some light on my latest challenge...
I have a 3.0 mercruiser running EST ignition.
I have set the base timing as per the manufacturers recommendations -
1. Start engine and allow to reach operating temperature.
2. With engine running, install a jumper wire across
the two WHITE leads on the distributor.
3. Bypass the shift interrupt switch by disconnecting
wires at shift interrupt switch. Temporarily join the
engine harness wires together.
4. With timing light connected, check timing. Timing
should be 1? BTDC.
5. If required, loosen distributor hold down clamp
and rotate distributor to obtain specified timing.
6. Secure distributor hold down clamp, and recheck
timing as above.
7. Reconnect the two wires to the shift interrupt
switch. Remove jumper wire at distributor white
leads.
8. With timing light still connected, and engine at
IDLE, verify that timing did advance to 12? BTDC,
(plus or minus 2?). At 2400-2800 RPM maximum
(total) advance is obtained and should be 27?
BTDC (plus or minus 2?).
All this goes fine except when I recheck the timing with all wires back to default I find the timing is still at 1 degree atdc.
When 1st start the engine and check the timing it is at 8 degrees btdc then the rpm drops and the timing has shifted to 1 degree atdc??
It seems that it is going back into base timing by itself...
When I increase the rpm it advances as per normal specs...
Any ideas??
Cheers
Mark
should be 1? BTDC.
timing as above.
leads.
Any ideas??
Cheers
Mark
