Southtowns27
- Jun 16, 2013
- 73
Hi all, Boat is an '86 Wellcraft 260 Aftcabin with a Chevy 350 (260 horse) and an alpha 1. Yesterday we were out cruising at about 18 mph, which is about 2900 RPM. Suddenly the sound of the engine changed and I noticed a slight vibration. Engine RPM and speed stayed the same, it just sounded different, almost like the exhaust got louder. I backed down on the throttle for a few minutes and everything seemed normal, so I accelerated back up. Under acceleration it seemed to "slip", like a slipping clutch or an auto tranny low on fluid. If I accelerated slowly it would hang on, but after a point, maybe 3600 RPM it would slip again. At low speeds it works fine and still shifts fine. I made it back to the dock and opened the engine compartment. I didn't notice the burnt rubber smell or any bits of rubber by the engine coupler. (The engine was replaced 4 years ago before I had the boat, so I would assume it was replaced at that time, but who knows). I pulled the boat out of the water this morning to check the prop. It has a 16x16 prop with the Flo-Torq hub. The first thing I noticed was that the nut was loose. Not backed way off, but loose enough that the lock plate was wiggling around. I took the prop off and the plastic liner in the prop looks fine, as do the splines on the shaft and inside the bronze collar. I'm kind of at a loss here for what's causing this... It doesn't seem to me that the loose prop nut would cause this, but could it?? If that's not the case it looks like the engine is coming out to check the coupler...ugh. Any insight would be appreciated!
