My father-in-law destroyed my merc 5.0 MPI with a shoddy winterizing job. Cracks in the block and manifolds so this perfectly good motor is now junk. It is an Alpha Drive (it's at the shop so I can't get the s#, sorry.) This stock motor ran great if a bit weak for the 4700Lbs of my 2009 220EX Crownline. So, I thought I'd take this opportunity to upgrade to a 5.7L MPI. From what I hear everything that bolted on the 5.0 will work directly on the 5.7--anyone ever done this and if so, what problems will I run into? . Are there any timing or jetting issues I need to worry about with this switch? Is it just a really bad idea? I know the Alpha has a 300hp limit, but I don't think the 5.7 MPI goes above 300 so that shouldn't be an issue. Also, I'm considering a reman from Jasper or Michigan Mortorz. Any suggestions for a reputable mail order engine supplier would be helpful. I tried searching for this info in the threads but had trouble with the search engine and got hundreds of unrelated posts. I apologize in advance if this is a redundant post. If so, would someone supply a link so I can check out what's been said? Thanks in advance and this is a great forum.
regards
everett
regards
everett
