Hi all. I have a 1977 SeaRay V197 with a 305 that has a cracked block. I've purchased a 1964 327 with Fuelie heads (which I do not intend to use) that I plan on installing in place of the 305. Currently the outdrive and motor have been removed and I'm starting to determine what all I need to to do this engine before installing it. I dont know much about it other than it's probably had the cam changed and seemed to run really well (so I'm told) before it was removed from the 1964 Chevy II.
My intention for this boat is to putt around the lake and do some wake boarding and tubing. The putting around will be 70% of the usage. The boat is old and possibly has some weak wood. I'm not real worried about that as I can pull the boat out and pull it apart any time so if it develops an issue I'll take care of that when the time come.
I'm planning on pulling the fuelie heads from the 327 and sell them to recoup some money. So I'll be installing the heads from my 305. My questions are mostly about what I may need to do to the 327 other than the normal stainless head gaskets and brass plugs. I'll put the heads, intake, carb, ignition, fuel pump, starter, alternator and water pump from the 305. Does anyone know if the cam's are swappable? I'm on a tight budget so I'd like to keep this cheap if possible. My first intent was to just drop it in while gather parts to pull it out and redo it the way I'd like so any suggestions for longevity without rebuilding would be great.
Thank you all for you help!
