Re: lower unit swap on Mercruiser inline 6 outdrive
After dropping the lower and checking the impeller I later discovered...after initial post...that the lower drive shaft seal ....(I had put a new one in with the 1st impeller replacement) had been shredded. There was NO second seal.
The O-ring had been totally vaporized except for a 1/4" section. ....
If that is the case, then you would have lost the oil in the upper part of the drive, and it would have been replaced with water and eminently damaged. I hope that is not the case! Refer to an exploded drawing of your drive to see where those two seals are in the upper drive. I am hard pressed to believe you dont have two seals there. And based on you saying the lower seal was shredded, it sounds like the O-ring got caught in the seal during reassembly (common), causing premature failure. Word on the street is to leave that O-ring out, because it is not needed (the lower seal supposedly does the job). Of course, you have to have two seals to make it work right!
That's another reason why I remove my whole drive to do impeller replacement (along with other annual stuff). On reassembly (if you just dropped the lower), you cant see the "finished product" (i.e., the shaft where it penetrates the lower seal) to make sure it is OK. Of course, the post assembly pressure test would also indicate a problem if there was one. You do perform a post assembly pressure test, right?
