BlakeBecker37130
- Jun 11, 2013
- 18
New member looking for a helping hand. I recently decided to do do an ignition tune up on my 1986 140. I have never played with points or timing but have the shop manual, tools and the job instructions look straight forward and easy enough. The engine was operating fine with the old parts, they just looked worn and in need of replacement. I pulled the cap, rotor, points and condensor. I replaced all of these things and set the dwell for the points with my meter around the middle range of 30-31 deg. When I put every thing back together the boat would not idle only sputter shake and run very rough, backfire through the carb etc. I did not have a timing light, but decided to loosen the distrib. and adjust it a bit. This only made thngs worse. Since this I have tried just about every thing. I lined the timing marks up @ 6 deg btdc
and rotated the distrib to match the #1 plug wire with the rotor. Still wont run I have a timing light now but cant even keep it running long enough to see the timing marks? Did I possibly mess up the valvetrain with my initial distb. adjustment. Im @ a loss of what to do next. Any info on this would sure be a great help
