1984 Sea Ray 120 mercrusier sprotic misfire. HELP!!!
Chance12
Hi,
I tried everything!!! Rebuilt the carb, new fuel filters, fuel line, cleaned tank, non-ethanol fuel, points, condenser, coil, plugs. It runs perfect for a while. 30-45 mins. then out of nowhere it will start breaking up at higher RPMS and at the same time if you run any extra electrical load on the engine like( trim motor, blower, ect) it gets worse and almost wants to stall.
Please help if you have any ideas where to look.
Thanks
alldodge
Re: 1984 Sea Ray 120 mercrusier sprotic misfire. HELP!!!
Sounds like an electrical issue. Chech your connections from the battery including the grounds. They all need to be clean and tight. While checking look for corrision inside the crimped connectors.
Chance12
Ok, Where are these crimped connectors?
alldodge
Crimped connectors are any connection which is crimped using a crimpping tool, such as many of the battery to engine connectors. Some manufactures solder connections others crimp the lug onto the wire. They come in small and large sizes. Electrical issues are hard to find. You may look at a wire and it looks great, then you pull on it and it comes apart
Volphin
Sounds like the coil is breaking down as it gets hot. Check and clean the electrical connections on the coil, and her grounds then retest. Also measure the coil for 12v in while it is missing. If it's less, then the problem is electrical. If voltage is OK, the coil is shot, and can be confirmed by testing it with a multimeter.
Chance12
I found a little corrosion in the ground by the starter. Checked all the conections that I could find. Hopefully I found it.
Chance12
I have tried two different coils. One orignal and one new Napa coil. 12volts at the coil when is runs rough. It will idle-2000 rpms perfect while it breaks up in higher rpms.
thumpar
What ignition do you have? If it is still point and condenser with standard coil you should only have around 7-9 volts at the coil.
Chance12
Yeah I should have been more clear. It does only have 8.5 volts while running. I put a jumper wire from the battery to the coil for a second to see if it would clear up....it didn't.
dubs283
is the alternator charging properly??
heavy_breeze
Bushings in your distributor could be loose, or your timing belt is shot. Is your distributor bolt to engine not secured properly? Sounds like distributor/timing issue.
thumpar
There is no timing belt just gears. Those don't usually cause any issues for the life of the engine.
alldodge
Thanks
Still belive it is an electrical issue, I think the getting at running temp is just happens because it takes that long to show up. Did you ever restart the engine after this started happening? If so did it crank slower then normal and what shape is the battery in?
stonyloam
Check your fuel tank vent, it may be plugged (creating a vacuum when you draw the fuel down) and reduce the amount of gas you can deliver to the engine. If it happens again try removing the gas cap and putting it back on, see if that helps.
alldodge
Stonyloam - that sounds like a real good possability. Had a stand alone generator which did the same thing and about drove me nuts until I accidently found it.
Chance12
I have tried that and no difference. also when I fill the boat some gas will shoot out of the vent when the tank is full.
