Have 1983 Mercruiser 228 with power steering. Steering wheel does not move the outdrive. How do I remove the cable as it appears to be stuck somewhere in the tube? I have so far only removed the clevis pin where the cable attaches to the outdrive. In the picture there are 3 nuts (#'s 1 to 3) plus what appears to be a clip of some sort (#4).
Which ones need to be removed?
Also, how do I unstick the cable if it is stuck in the tube?
Thanks!
Thanks!
