Re: unknown piece fell while removing out drive
motor boater, fill the guys in on what happened, so they can help trouble-shoot everything and get your boat back in tip-top shape.
The remnants of the shutter look pretty toasty, all the rubber is gone.
ok, My boat overheated over the memorial day weekend, I have not serviced it in the last 2 1/2 years since I purchased it, and I don't know when the previous owner last serviced it. I know I know, i'm an idiot you don't have to tell me, I've already been kicking my own a** about it lol.
so I have removed my outdrive to take a look at and change the impeller and housing. due to the overheating, people on this forum have suggested I look at the gimbal bearings and bellows as well.
You should still remove what Don listed in post #7 above and replace with the parts in post #8.
Yes, remove the old grease and pump in new until you see good grease showing up.
Mark
you said pump new grease???
1. do I do this through the grease valve on the gimbal ring/housing?? (don't remember which has the grease fill valve, I know one of them does).
2. also the u joint has a grease fill valve on it. how much grease should I put in there? and of what kind??
3.and when you say remove the old grease, you do mean clean the grease out of the gimbal bellow right?
