3.0 LX carb rebuild kit part number?
smassey22180
Can someone tell me what the correct carb rebuild kit is for a 1995 Mercruiser 3.0 LX 0F556016? Thanks to everyone who makes this forum great.
glens5
Re: 3.0 LX carb rebuild kit part number?
You will have to have the number of the carb to know for sure. I just went through this whole exercise with my 1996 3.0 LX. There where a few different possibilities as to which carb the engine came from the factory with as well as the possibility the carb had been replaced over the years. I had the engine number too but not the carb number and the boat was in winter storage so i had to wait until this spring to source one out. With the right carb number E-bay will almost certainly be a good place to start.
smassey22180
I found numbers on the front and side of the carb. Front number is 05924A-1 with 5101 under it. Side number is 610433- with a few more numbers after and under that I can't read easily. Hopefully the number on the front is the correct serial number.
smassey22180
Part number on the front of the carb appears to be a short version of 3310-805924A-1. Only issue now is most rebuild kits are for an A2 and mine is an A1. Getting closer.
