Valve on raw water inlet for B3
agallant80
Don't know if this is a repair issue but I would like to put a valve or seacock on the raw water inlet for my B3. Is there some merc part to do this or do I just need to beasure the tube size from the drive to the raw water pump and head down to the boat store to find a valve that will fit?
Don S
Re: Valve on raw water inlet for B3
No Merc part, but what ever valve you use, you don't want the valve or fittings to reduce the ID size smaller than that of the raw water pump itself.
