Hey folks,
I have to change out the Bravo u-joint bellows on our 98 Monterey, due to a u-joint issue we had recently. The bellows is torn, and must be replaced. The drive is already removed, and I have installed the new u-joints and it is ready to back on.
Can I simply remove the exhaust bellows, tilt the bell housing up, and get the new u-joints bellows in position from underneath, or do I have to removed the hinge pins and do it that way? I'm hoping I can save some time by just installing it from underneath.
Has anyone else done it this way?
Thanks for your replies!
