As some of you know, I replaced a bad gray tach wire from the Ign Coil (-) to the tach. When that was done, the white/green kill switch wire was no longer mated to the gray tach wire. So i ran a brand new size 14 wire from the killswitch to the (-) coil.
Now when I touch the w/g wire to the coil (-), it stalls. It starts fine without that wire but as soon as I touch w/g to (-) on coil, it sparks and dies.
Current:
Now that i think about it.. it shouldnt be grounded until switch is hit right? We checked the switch for continuity and it didnt beep till button was hit. Therefore the circuit was broke until it was hit (sounds right). Could it be the switch you think?
Current:
