I am having trouble with my power trim on a 1990 4.3 mercruiser. I have the unit with the yellow cap for the reservoir, seems to be a pretty common unit. I cant get it to do anything, so I took the small motor off and it will run when connected to the negative and either the green or blue cable hooked to positive. I seem to have a problem with this part
I have 12vdc on the middle screws but nothing on either the right or left screw, this is where the blue and green lines go. Any opinions on this and what is this part and where can I buy one?? Thanks
