1983 Mercruiser 120 hp 151 cid. Motor was rebuilt and sat for a year before it was installed. Boat runs great but a noise is coming from the timing cover. Removed motor and took off timing cover. Cam shaft gear is scraping the cover in about a 3/8" area at the end of the cam gear teeth. Cam gear is flush on the cam. The gasket was a paper gasket. Was this the right gasket? Should it have been a cork gasket to shim the cover out? What else can I look for? Thanks in advance.
