Replaced the starter switch (key) cleaned the batter terminals.
when I turn the key I just hear a click from the solenoid, after 4 or 5 times it will finally turn over, runs great once it starts.
Starter going bad? Not sure what else it could be.
Mine is a 260 mercrusier of unknown vintage.(at least a 1987). Has a stock four barrel quadra jet on it. The starter will not engage flywheel. All I get is a clicking noise coming from the starter slave solenoid. I have replaced the starter and the starter slave solenoid. I also checked and cleaned all the grounds. When I jump the starter (with screw driver) the starter motor runs, but the starter solenoid does not engage. I'm at a loss. Need help. All of these symptoms were there before I changed the starter and starter slave solenoid.
