Changing the belt in this 4.3L Mercruiser(picture)
tbmaciii
Hi all,
New to boating, just got the boat running right on the water after changing the fuel filter and inline filter near the carb. After I start the boat, the belt makes a very, very loud screeching noise. It has never been replaced so I figured I should go ahead and take of that tomorrow morning. Are there directions or a manual onloine, and does anyone know what size belt and what type of engine oil are used, since I will change the oil tomorrow as well. Thanks
r.j.dawg
Ensign
Re: Changing the belt in this 4.3L Mercruiser(picture)
Welcome TBM. The experts will need a year and engine serial number to give any kind of help. You've come to the right place.
achris
More fish than mountain goat
You have the belt set-up incorrectly.... Which will account for the noise. I'll go and photograph my engine for you and you can see how it should be... Be back in a second....
achris
OK.. Here's your picture. If you really want to replace the belt with a new one, it's a Gates 6PK1930. Get it at any parts shop and pay about half what Merc would charge you for the same thing.
attachment.php
Don S
Oops, Too late.
tbmaciii
I see how yours are, however the larger center pulley has a smooth outside which means it should touch the outside of the belt. Is my set up with pulleys just different then? Thanks
Don S
That is the way it's supposed to be. Put the belt on by the picture or the drawing from the manual I posted, and it will work.
What is your Merc serial number, then we can get you the correct belt number.
