steves86ta
- Jan 15, 2013
- 56
Hi Guys,
Im sorry to bring this up again i have been searching for days, but still am having a hard time getting my questions answered.
I just picked up two exhaust manifolds for a Great price. They are the center riser manifolds by mercruiser.
My current configuration is a bone stock 1980 Mercruiser 228 with the stock logs (which are cracked and leaking)
I can and will take pictures tonight if need-be.
My questions are, what is involved to add these newer style center riser style manifolds as far as the cooling system goes.
I have read that i may or may not need a new thermostat housing. I already need to replace the hoses and plan on doing that so if i need custom hoses that is fine. I really dont want to spend 300 on a thermostat housing if my stock one can be plumbed to work correctly.
Does anyone have a picture or diagram that i can use? Or am i SOL and need to buy a new housing?
Is it possible to get rid of the "warm water" cooling and run straight cold water from the outdrive?
Any other suggestiosn or tips will be very appreciated.
I appreciate your time
thank you
Steve
thank you
Steve
