Georgia Boater
- May 3, 2013
- 10
I recently bought a 87 Glasstream Cutlass 172 with a Mercruiser 3.0. Owner told me it needed points before it would crank. Well going against my gut feeling I bought it anyway not hearing it run.
Instead of messing with points I bought the electronic conversion kit and installed it. Changed plugs /wires /distributor cap and rotor as well. Engine would not start. Engine will turn over but never starts. ( separate post).
As I was changing the plug wires I noticed that the coil cavity was full of oil. It looked like new oil. I cleaned it out and tried a few more times to start motor and it will not crank. I rechecked the coil and more oil was inside the coil cavity. Does the coil have moving parts on the inside that requires lubed and now its damaged and needs replaced. Never seen oil inside coil before. I thought it may be some kind of preservative oil the owner put in to keep from corrosion but not sure.
Thanks for any comments
