Mercruiser Engine shift-switch stall not working
two tone
My 1984 mercruiser Alpha drive does not cut out the engine when shifting so i get slight grinding going into gear.I went through the cable adjustment procedure and the switch does work when moved by hand.Any thoughts on this?
Thanks
Don S
Re: Mercruiser Engine shirt stall not working
I moved this thread from Dockside Chat.
The shift interrupt system has nothing to do with shifting into gear, only coming out of gear while in the water.
If it's grinding, either the idle rpm is too high, you are shifting too slow, or the cables are worn/binding/out of adjustment.
two tone
Thanks, i was trying to figure out how to fix a spellig error and move to the correct spot.
Thanks, i was trying to figure out how to fix a spelling error and move to the correct spot.
Ayuh,... Welcome Aboard,.... Don got ya moved over here, 'n I fixed yer title typo,...
Good Luck, 'n tell Us more 'bout yer shiftin' issue....
