Lil captain
- Apr 17, 2013
- 9
Bought a 02 rinker 232 5.0 carb generation II outdrive and have spent a lot of quality time with it, bellows, impeller, stereo system, fresh water pump, installed dual batteries and perko switch. The boat came with a mercury 4500 shift control that has a rocker switch for the power trim, which has a diagram of a boat on the trailer and up and down arrows . I can adjust the trim limit sender to 21.75+or- and all works well, but cannot find any other switches for getting the outdrive up to the trailer position. My question is when working properly is the rocker switch a two or three position switch, and if its only up and down, what overrides the trim limit to get to a trailering position. Thanks in advance
